The 8849 Tank 3 Pro is a new rugged smartphone that aims to combine durability with high-end features. This device stands out with its built-in projector and enormous battery capacity, making it an intriguing option for outdoor enthusiasts and professionals who need a tough, long-lasting phone.
Key Features
Built-in DLP Projector
One of the Tank 3 Pro’s most unique features is its integrated DLP (Digital Light Processing) projector. With a brightness of 100 lumens and adjustable focus, this projector allows users to display content on any flat surface. This feature could be particularly useful for:
- Outdoor movie nights while camping
- Impromptu business presentations
- Sharing photos or videos with friends
The projector’s integration into a rugged smartphone design sets the Tank 3 Pro apart from typical projector-equipped devices, which are often bulky and fragile.
Massive Battery Capacity
The Tank 3 Pro boasts a 23,800mAh battery, which is several times larger than what’s found in most smartphones. This enormous capacity allows the device to run for multiple days on a single charge under normal usage conditions. For context, many flagship smartphones have batteries in the 4,000-5,000mAh range.
To complement this large battery, the Tank 3 Pro supports 120W fast charging. This technology can charge the battery to 90% in approximately 90 minutes, which is impressive given its size. Additionally, the phone can act as a power bank to charge other devices, adding to its utility in outdoor or emergency situations.
Rugged Design
As a rugged smartphone, the Tank 3 Pro is built to withstand harsh environments:
- IP68 rating for water and dust resistance
- Military-grade durability standards
- Built-in cooling fan to prevent overheating during intensive tasks
These features make the Tank 3 Pro suitable for use in construction sites, outdoor adventures, or any situation where a standard smartphone might be at risk of damage.
Performance Specifications
The Tank 3 Pro doesn’t skimp on performance, featuring:
- MediaTek Dimensity 8200 octa-core processor
- 5G connectivity for fast data speeds
- Up to 36GB of RAM (18GB physical + 18GB virtual)
- 512GB of internal storage, expandable up to 2TB with a microSD card
- 6.79-inch FHD+ display with a 120Hz refresh rate
These specs put the Tank 3 Pro in line with many flagship devices in terms of raw performance and should provide smooth operation for most tasks.
Camera System
The Tank 3 Pro features a versatile camera setup:
- 200MP main camera for high-resolution photos
- 64MP night vision camera for low-light photography
- Wide-angle and telephoto lenses for varied shooting scenarios
This array of cameras provides flexibility for different photography needs, from landscape shots to detailed close-ups.
Additional Features
- Camping light with adjustable brightness and emergency warning mode
- L1+L5 dual-band GPS for precise navigation
- Android 13 operating system
Pricing and Availability
The 8849 Tank 3 Pro is priced at $599.99 in the United States and £470 in the UK. It’s available through various online retailers and the manufacturer’s website.
The 8849 Tank 3 Pro combines rugged design with high-end smartphone features and unique additions like a built-in projector. While its bulk may not appeal to everyone, it could be an excellent choice for those who need a durable device with long battery life and the ability to project content on the go.
