3i P10 Ultra Robot Vacuum Brings Advanced Cleaning Tech to Homes
The smart home cleaning market continues to evolve with innovative products aimed at making household chores easier. One of the latest entries is the 3i P10 Ultra, a robot vacuum and mop combo that packs some impressive features into a compact package. Let’s take a closer look at what this new cleaning assistant has to offer.
Powerful Suction and Mopping Capabilities
At the heart of the P10 Ultra is its robust 18,000 Pa suction power. This places it among the most powerful robot vacuums currently available to consumers. The strong suction allows the P10 Ultra to effectively pull debris and dust from deep within carpets and floor crevices.
The P10 Ultra doesn’t just vacuum - it also mops floors with some clever engineering:
  • Dual spinning mop heads rotate at 220 RPM to scrub floors
  • UltraReach mop automatically extends to clean along baseboards and in corners
  • Mop applies consistent downward pressure to mimic manual mopping action
For homes with both hard floors and carpets, the P10 Ultra uses ultrasonic sensors to detect different surfaces. When carpets are detected, the mop heads automatically lift 10.5mm to avoid soaking rugs and carpets.
Advanced Navigation and Object Detection
To navigate homes efficiently, the P10 Ultra employs a combination of technologies:
  • LiDAR for room mapping and navigation
  • 3D structured light sensors for depth perception
  • AI-powered camera for object recognition
This multi-sensor approach allows the robot to create accurate 3D maps of your home. The AI can recognize over 100 types of common household objects and obstacles. This helps the P10 Ultra avoid things like shoes, pet bowls, charging cables, and even pet waste.
Users can access the 3D maps through the 3i mobile app. The app allows you to set room-specific cleaning zones, adjust vacuum and mop settings, and customize cleaning schedules.
Self-Maintaining Dock Station
One of the most convenient features of the P10 Ultra is its multifunctional docking station. This base handles several maintenance tasks automatically:
Step 1: When the robot returns to dock, the station cleans the mop pads using 140°F (60°C) hot water and mechanical scrapers.
Step 2: The mop pads and base tray are cleaned at a 45° angle for more effective debris removal.
Step 3: Hot air is used to dry the mop pads, preventing mildew growth.
Step 4: The robot’s water tank is automatically refilled and cleaning solution is added.
Step 5: The dustbin is emptied into a large capacity bag in the dock.
This self-maintaining system means less work for users. The dust bag only needs changing approximately every 70 days, depending on usage and home size.
Smart Features for Pet Owners
The P10 Ultra includes several features designed specifically for homes with pets:
  • Increased suction in areas where pets spend time
  • Anti-tangle brushes to prevent hair wrap
  • TangleCut system in the dock to slice through wrapped hair
  • AI recognition to avoid pet waste and food bowls
These pet-friendly features make the P10 Ultra a strong contender for households dealing with pet hair and associated messes.
App Control and Smart Home Integration
The 3i mobile app gives users full control over the P10 Ultra’s functions:
  • Set cleaning schedules
  • Customize cleaning modes for different rooms
  • View cleaning history and reports
  • Adjust suction power and water flow for mopping
The P10 Ultra is also compatible with popular voice assistants like Amazon Alexa and Google Assistant. This allows for hands-free control, such as starting a cleaning cycle with a voice command.
Pricing and Availability
The 3i P10 Ultra has recently launched in the US market with a regular retail price of $1,099. However, as part of its initial launch promotion, it’s being offered at a discounted price of $799 for a limited time through select retailers.
The 3i P10 Ultra brings together powerful suction, advanced mopping capabilities, and smart features in a package designed to tackle a variety of household cleaning tasks. While it comes at a premium price point, its self-maintaining dock and robust cleaning abilities may make it a worthwhile investment for those looking to automate their floor cleaning routine.
