Camera issues in Windows 11 can disrupt video calls and online meetings. This guide covers proven solutions to get your camera working again, whether you’re using a built-in webcam or an external camera.
For external webcams, first try disconnecting and reconnecting the device, or testing it in different USB ports to eliminate basic connection problems.
Method 1: Enable camera privacy settings
Windows 11’s privacy settings often block camera access. This is typically the root cause and easiest to fix.
Launch Settings using Windows + I or click the Settings icon in Start menu
Navigate to Privacy & security in the left menu
Find and select Camera under App permissions
Enable Camera access if it’s turned off
Turn on Let apps access your camera and enable permissions for specific apps
Method 2: Check physical camera controls
Many devices have hardware controls that might be blocking your camera.
Look for a physical camera cover or slider on your device
Find the camera function key on your keyboard
Check for side-mounted camera switches
Method 3: Update camera drivers
Outdated drivers frequently cause camera malfunctions.
Right-click Start and select Device Manager
Expand the Cameras section
Right-click your camera and select Update driver
Choose automatic driver search
Method 4: Run Windows camera troubleshooter
The built-in troubleshooter can automatically detect and fix common issues.
Open Settings with Windows + I
Select Bluetooth & devices
Click Cameras
Select your camera device
Click Troubleshoot
Method 5: System restart
A simple restart can resolve temporary system glitches.
Open Start menu and click Power
Select Restart
Method 6: Reset camera app
Resetting the Camera app can fix software-related issues.
Open Settings
Navigate to Apps > Installed apps
Find Camera in the app list
Click the three dots and select Advanced options
Scroll down and click Reset
Method 7: Review antivirus settings
Security software can block camera access. Check your antivirus settings and temporarily disable it to test if it’s causing the problem.
If these solutions don’t work, your camera hardware might need repair or replacement. Contact your device manufacturer’s support for hardware-specific assistance.
