Where to Find The White Lotus Season 3 a Streaming Guide
The White Lotus, a television series created by Mike White, has garnered Emmy Awards and centers around the staff and visitors of a high-end resort chain. Originally conceived as a limited series, it has evolved into a successful anthology franchise. Given the 26-month gap between the Season 2 finale and the upcoming third season, fans are understandably eager for information. If you’re keen to discover how to watch The White Lotus Season 3, this guide is for you.
How to Watch The White Lotus Season 3
The most convenient way to watch The White Lotus Season 3 will be via streaming services that carry HBO content. Let’s explore the options.
Method 1: Max (formerly HBO Max)
Step 1: Subscribe to Max.
Max is the primary streaming home for HBO content, so a subscription is your best bet.
Step 2: Search for “The White Lotus” on Max.
Use the search function within the Max app or website to locate the series.
Step 3: Select Season 3 once it becomes available on February 16, 2025.
New episodes should appear on the platform on the release date.
Method 2: Sky TV and Now TV (UK)
Step 1: Subscribe to Sky TV.
If you are in the UK, Sky TV offers access to HBO shows.
Step 2: Subscribe to Now TV.
Alternatively, subscribe to Now TV, Sky’s streaming service.
Step 3: Select an Entertainment plan for £9.99.
There are two options: one that doesn’t allow cancellation until 6 months have passed, and a fully flexible one that you can cancel at any time.
Step 4: Choose the Entertainment and Cinema plan for £19.98.
Note that this plan does not allow cancellation before 6 months.
Method 3: Disney Plus Hotstar (India)
Step 1: Subscribe to Disney Plus Hotstar.
Reports suggest that The White Lotus Season 3 will be available on Disney Plus Hotstar in India.
Step 2: Search for “The White Lotus” on Disney Plus Hotstar.
Use the search function to locate the series once it’s released.
Step 3: Select Season 3 once it becomes available.
Ensure you have the correct subscription level to access HBO content.
With its release on multiple platforms, accessing The White Lotus Season 3 should be straightforward, allowing fans globally to dive into the next chapter of this captivating series. Be sure to check your local listings and streaming service availability for accurate information.
