Troubleshooting Windows 11 optional features installation problems
Having trouble installing Windows 11 optional features like Hyper-V, WSL, or Windows Hello Face? Many users encounter installation failures or error messages when trying to add these functionalities. Here are proven solutions to get your optional features working properly.
Method 1: Run system repair tools
  1. Launch Terminal as administrator by searching for “Terminal” in the Start menu and selecting “Run as administrator”
  1. When prompted by User Account Control, click “Yes”
  1. Select “Command Prompt” from the dropdown menu (chevron icon)
  1. Type this command and press Enter:
DISM /Online /Cleanup-Image /RestoreHealth
  1. After DISM completes, run System File Checker:
SFC /scannow
  1. Restart your computer once both scans finish
Method 2: Configure windows module installer
  1. Search for “Services” in Start menu and open the Services app
  1. Locate and double-click “Windows Modules Installer”
  1. Set “Startup type” to “Automatic” and click Apply then OK
Method 3: Update Windows
  1. Open Settings from Start menu
  1. Navigate to Windows Update
  1. Click “Check for updates” and install any available updates
Method 4: System restore
  1. Open Control Panel by searching for “Control” in Start menu
  1. Click on Recovery
  1. Select “Open System Restore”
  1. Click Next in the System Restore window
  1. Choose a restore point and click Next
  1. Review affected programs using “Scan for affected programs”
  1. Click Finish to start restoration
Method 5: Create new admin account
  1. Open Settings app
  1. Select Accounts
  1. Click “Other users”
  1. Select “Add account”
  1. Enter a different Microsoft email
  1. Complete account setup
  1. Change account type to Administrator
