Assassin’s Creed Valhalla crashes can stem from several sources, including driver issues, file corruption, or resource limitations. These crashes might occur during startup, gameplay, or even during cutscenes. Outdated software, background processes hogging resources, or your GPU/CPU being pushed beyond their limits are often the culprits.
Fortunately, several solutions can address these crashing issues.
Set High CPU Priority
Prioritizing the game in Task Manager ensures it receives more processing power, minimizing interruptions from other applications.
Step 1: Launch the game.
Step 2: Open Task Manager. You can do this by right-clicking the taskbar and selecting Task Manager
Step 3: Navigate to the Details
tab.
Step 4: Right-click on Assassin’s Creed Valhalla.exe
Step 5: Select Set Priority
then choose High
Step 6: Confirm the change and test the game.
Adjust Compatibility Settings
Modifying compatibility settings can improve game stability by reducing conflicts with Windows. Key adjustments include disabling full-screen optimizations, using compatibility mode for older Windows versions, and granting administrator privileges.
Step 1: Right-click the game’s .exe
file, typically found in the installation folder, and select Properties
Step 2: Go to the Compatibility
tab.
Step 3: Check Run this program as an administrator
and Disable full-screen optimizations
Step 4: Optionally, enable Run this program in compatibility mode for
and select Windows 7
or Windows 8
Step 5: Click Apply
> OK
to save your changes.
Step 6: Launch the game to check if the crashes are resolved.
Increase Virtual Memory
Virtual memory uses a portion of your storage drive as extra RAM, which can prevent crashes if your system has insufficient physical RAM. This is especially helpful for systems with 8GB of RAM or less.
Step 1: Press Win + S
, type View Advanced System Settings
, and press Enter.
Step 2: Under the Performance
section, click Settings
Step 3: Go to the Advanced
tab, then click Change
under the Virtual Memory
section.
Step 4: Uncheck Automatically manage paging file size for all drives
Step 5: Select Custom size
and set the following:
Initial size (MB)
: Set this to 1.5 times your installed RAM. For example, if you have 8GB of RAM, enter 12288 (8GB * 1024 * 1.5).Maximum size (MB)
: Set this to 3 times your installed RAM. For example, if you have 8GB of RAM, enter 24576 (8GB * 1024 * 3).
Step 6: Click OK
> Apply
> and restart your PC.
Step 7: Test the game again.
Verify Game Files
Corrupted game files are a common cause of crashes. Verifying the integrity of the game files ensures that no problematic or damaged files are causing the issue.
Step 1: Open your game launcher (e.g., Steam) and go to your game Library
Step 2: Right-click on Assassin’s Creed Valhalla
Step 3: Navigate to Installed Files
then click Verify integrity of game files
Step 4: Wait for the scan to complete, and then relaunch the game.
Lower Graphics Settings (For Low/Mid-Range PCs)
If you are using a low to mid-range PC, crashes can occur due to insufficient memory. Reducing graphic settings can lower the game’s RAM usage, potentially resolving crashes caused by memory limitations.
Step 1: Launch the game and open Settings
Step 2: Go to the Graphics
section and reduce the preset settings to Medium
or Low
Step 3: Disable demanding effects like shadows, anti-aliasing, or ambient occlusion.
Step 4: Play the game for 15–20 minutes to check for stability.
By systematically applying these troubleshooting steps, you should be able to identify and resolve the crashing issues in Assassin’s Creed Valhalla, allowing you to fully enjoy the game.
