Are you looking for a powerful computing solution that doesn’t dominate your desk space? The Meerkat mini PC from System76 could be the answer. This compact machine offers a compelling blend of performance and a small footprint, ideal for users who need a streamlined setup.
Small Size, Big Performance
The Meerkat mini PC boasts an incredibly compact design, with dimensions of just 4.5 inches square. For even greater space savings, utilize the VESA mount to discreetly position it behind your monitor.
Despite its diminutive size, the Meerkat packs a punch. It features an Intel Core Ultra processor, capable of handling demanding workloads. Integrated Intel Arc graphics further enhance its capabilities, enabling gaming, streaming, and other multimedia experiences.
What Makes the Meerkat Special?
Fast Processing: Equipped with up to 16 cores for rapid performance.
Plenty of Memory: Features fast DDR5 RAM, which is 62% faster than previous models.
Lots of Storage: Supports up to 16TB of storage for ample file capacity.
Multiple Displays: Connect up to four monitors to the Meerkat.
Fast Internet: Includes 2.5-Gigabit Ethernet and Wi-Fi 6E for high-speed network connectivity.
Open Source Firmware: Uses System76 Open Firmware based on coreboot, ensuring fast and secure boot times.
What Can You Do With a Meerkat?
This versatile machine opens up a range of possibilities. Here are a few potential applications:
Home Server: Its storage capacity and processing power make it suitable for use as a home server.
Media Center: Connect it to your TV to transform it into a media hub.
Work From Home: Its compact size helps create a clutter-free workspace.
Gaming: Enables game streaming to your television.
Maker Projects: Its capabilities make it perfect for tinkering and interfacing with boards like Arduino or Raspberry Pi.
Open Source Freedom
System76 emphasizes open-source principles, advocating for the right to repair and modify your computer. The Meerkat is designed for easy serviceability, allowing for upgrades and internal exploration.
Software and Operating System
The Meerkat mini PC offers a choice of open-source operating systems:
Pop!_OS 22.04 LTS.
Ubuntu 22.04 LTS.
Ubuntu 24.04 LTS.
System76 also develops its own desktop environment called COSMIC, designed to promote efficiency.
Meerkat Mini PC Technical Specification
Feature | Specification |
Form Factor | Mini PC, 4.5-inch square |
Processors | Intel Core Ultra 5 125H: Up to 4.5GHz, 14 Cores (4P+8E+2LPE) |
Intel Core Ultra 7 155H: Up to 4.8GHz, 16 Cores (6P+8E+2LPE) | |
Graphics | Integrated Intel Arc graphics |
Memory | Up to 96 GB Dual Channel DDR5 5600 MHz |
Storage | Up to 16 TB, 1 x M.2 PCIe Gen4 NVMe, 1 x SATA 2.5". System also supports 1 x M.2 (KEY M, 2242) with PCIe Gen4x4 for SSD |
Networking | 2 x Intel 2.5 Gigabit LAN, 1 x Wi-Fi 6E 802.11ax + BT 5.3 |
Front Ports | 1 x USB 3.2 Gen2 Type-A, 1 x USB4/ThunderboltTM 4 (Supports DP 2.1 display output), 1 x USB3.2 Gen2x2 (Type-C, Supports DP1.4a display output) |
Rear Ports | 2 x USB 3.2 Gen2 Type-A |
Video Ports | Supports Quad display, 2 x HDMI 2.1 TMDS, 1 x DP 2.1 (from USB4), 1 x DP 1.4a (from Type-C) |
Audio | 1 x headphone/microphone jack |
Operating System | Pop!_OS 22.04 LTS, Ubuntu 22.04 LTS or Ubuntu 24.04 LTS |
Power Supply | Dependent on CPU: Ultra 5 125H: 19V, 90W Power Adapter. Ultra 7 155H: 19V, 120W Power Adapter |
Dimensions | 117.5 x 110.0 x 49mm (4.63" x 4.33" x 1.93") |
Other Features | System76 Open Firmware powered by coreboot. VESA mountable. |
Starting Price | $799 |
Price and Availability
The Meerkat mini PC has a starting price of $799. You can purchase it directly from the System76 website.
The Meerkat mini PC’s combination of size, open-source philosophy, and performance make it a compelling option in the mini PC market.
