Samsung's Exynos 2600 Chip Shows Promising Early Production Results
The development of Samsung’s next-generation mobile processors continues, with updates emerging on both the Exynos 2500 and the more advanced Exynos 2600. While efforts are underway to optimize the Exynos 2500 for a potential release in the latter half of 2025, progress is also being made in refining the manufacturing process for the future Exynos 2600. Recent reports indicate a surprisingly positive yield from an initial production test conducted earlier in the week.
Samsung is conducting production test runs for the Exynos 2600 chip, utilizing SF2 (2nm) technology. According to a Korean media outlet, The Bell, citing sources within the industry, the initial test run on February 6 resulted in a production yield of approximately 30%.
This yield rate is considered promising at this early stage of development. A 30% yield signifies that roughly 30% of the chips produced on the wafer meet the required standards. While a 30% yield isn’t sufficient for mass production, it represents a strong starting point for Samsung’s 2nm process, suggesting that the yield rate should improve with further refinement.
The Exynos 2500 is based on a 3nm process, which means its development is independent of the 2nm Exynos 2600. Considering the Exynos 2500 chip has faced delays, Samsung aims to ensure a smooth development process for the Exynos 2600 to avoid further setbacks.
The company is aware that delays to both chipsets could have significant financial consequences. With the Exynos 2500 already experiencing delays, efforts are focused on preventing any further postponement of the Exynos 2600 and its 2nm SF2 process.
SF2 GAA (Gate All Around) technology is expected to deliver a 12% improvement in chip performance and a 25% increase in power efficiency compared to SF3.
Here’s a breakdown of the key takeaways:
  • The Exynos 2600 is being tested using Samsung’s 2nm process.
  • Early production tests show a 30% yield, which is considered good for this stage.
  • The Exynos 2600 aims for better performance and power efficiency than its predecessors.
  • Samsung wants to avoid delays with the Exynos 2600 due to prior delays with the Exynos 2500.
Samsung aims to deliver improved performance and efficiency with the Exynos 2600, and these initial results offer encouragement for its development.
