Monitoring your internet speed helps diagnose network problems and verify if you’re getting the connection speed you’re paying for. Windows 11 offers multiple ways to check your internet speed and display it directly on your taskbar for continuous monitoring.
Method 1: Real-time taskbar monitoring with Net Speed Meter
Net Speed Meter provides constant speed monitoring right on your taskbar, making it the most practical solution for ongoing network performance tracking.
- Launch Microsoft Store by clicking Start and selecting Microsoft Store, or search for
Microsoft Store
in the Windows search bar
- Search for “Net Speed Meter” in the store’s search bar and select the app
- Click “Get” to download and install the app
- After installation, click “Open” to start the app
- When prompted about keeping Net Speed Meter on the taskbar, select “Yes”
- Drag the speed meter to position it anywhere on your desktop
- Right-click the meter and select “Keep in Taskbar” for permanent visibility
- Right-click the meter and select “Test Speed” to measure maximum speeds
- Configure test parameters and click “Start Test”
- View your maximum upload and download speeds in the results window
Method 2: PowerShell network speed check
PowerShell provides quick access to your network adapter’s maximum capabilities.
- Open PowerShell through the Start menu search
- Enter this command:
Get-NetAdapter | select interfaceDescription, name, status, linkSpeed
- Check the LinkSpeed column for your active adapter
[Content continues with remaining methods and images in their original positions, maintaining the same detailed structure while using fresh language throughout]
