Firewalld
is the default firewall management tool on Red Hat Enterprise Linux (RHEL) based distributions such as Fedora, AlmaLinux, and Rocky Linux. This guide will cover some basic firewalld
operations.
Install and Enable Firewalld
Step 1: Install firewalld
using the dnf
package manager.
sudo dnf install -y firewalld
Step 2: Start the firewalld
service and enable it to start automatically at boot.
sudo systemctl enable --now firewalld
Step 3: Verify that the firewalld
service is running.
sudo systemctl status firewalld
Step 4: If you’re configuring a server, allow SSH traffic to avoid being locked out.
sudo firewall-cmd --permanent --add-service=ssh
Understanding Firewall Zones
Unlike some other firewalls, firewalld
utilizes the concept of zones to manage network traffic. It’s important to know which zone is the default on your system. While public
is a common default, your server’s configuration might differ.
Step 1: Determine the default zone.
sudo firewall-cmd --get-default-zone
Step 2: List the currently active rules in the default zone.
sudo firewall-cmd --list-all
Step 3: List all available zones.
sudo firewall-cmd --list-all-zones
Step 4: Display active zones.
sudo firewall-cmd --get-active-zone
In most cases, you’ll be working within the default public
zone.
Method 1: Using Direct Rules for Packet Forwarding (iptables Backend)
If you’re using iptables
as the backend and need to forward packets between clients (for example, in a VPN setup), direct rules offer precise control. Adapt the interface (wg0
) and subnet (10.10.10.0/24
) to your network configuration.
Step 1: Add rules to accept forwarding for the specified interface.
sudo firewall-cmd --permanent --direct --add-rule ipv4 filter FORWARD 1 -i wg0 -j ACCEPT
sudo firewall-cmd --permanent --direct --add-rule ipv4 filter FORWARD 1 -o wg0 -j ACCEPT
Step 2: Add rules to accept forwarding for the specified subnet.
sudo firewall-cmd --permanent --direct --add-rule ipv4 filter FORWARD 1 -s 10.10.10.0/24 -j ACCEPT
sudo firewall-cmd --permanent --direct --add-rule ipv4 filter FORWARD 1 -d 10.10.10.0/24 -j ACCEPT
Step 3: Restart firewalld
for the changes to take effect.
sudo systemctl restart firewalld
Step 4: List the direct rules to confirm your configuration.
sudo firewall-cmd --permanent --direct --get-all-rules
Method 2: Enabling Packet Forwarding (General Method)
Step 1: Enable IP forwarding in the kernel. Edit /etc/sysctl.conf
or create a new file in /etc/sysctl.d/
sudo nano /etc/sysctl.d/99-forwarding.conf
Step 2: Add the following line to the file.
net.ipv4.ip_forward = 1
Step 3: Apply the change.
sudo sysctl -p /etc/sysctl.d/99-forwarding.conf
Step 4: Enable masquerading on the external interface in firewalld
. Replace eth0
with your external interface.
sudo firewall-cmd --permanent --zone=public --add-masquerade
Step 5: Reload firewalld
to apply the changes.
sudo systemctl reload firewalld
Enable Logging for Firewalld
To help troubleshoot firewall issues, enable logging of denied packets.
Step 1: Enable logging for all denied packets.
sudo firewall-cmd --set-log-denied=all
When a connection is blocked, messages will be logged in /var/log/messages
Open Ports in the Firewall
If you host a website, you’ll need to allow HTTP (port 80) and HTTPS (port 443) traffic.
Step 1: Open ports 80 and 443 for web traffic.
sudo firewall-cmd --permanent --add-port={80/tcp,443/tcp}
If you run a mail server, you’ll need to open ports for SMTP (25), submission (587), IMAP (143), and IMAPS (993).
Step 2: Open necessary ports for mail server functionality.
sudo firewall-cmd --permanent --add-port={25/tcp,587/tcp,143/tcp,993/tcp}
If POP3 is required, open ports 110 (POP3) and 995 (POP3S).
Step 3: Open POP3 ports if needed.
sudo firewall-cmd --permanent --add-port={110/tcp,995/tcp}
Step 4: Reload firewalld
to apply the new rules.
Close Ports in the Firewall
To close a port, use the --remove-port
option.
Step 1: Remove the desired port.
sudo firewall-cmd --permanent --remove-port=25/tcp
Step 2: Reload firewalld
Rich Rules
Rich rules provide a more expressive way to define firewall rules.
Step 1: Add a rich rule to whitelist an IP address. Replace 12.34.56.78
with the actual IP.
sudo firewall-cmd --permanent --add-rich-rule='rule family="ipv4" source address="12.34.56.78" accept'
Step 3: To delete a rich rule, use the --remove-rich-rule
option.
sudo firewall-cmd --permanent --remove-rich-rule='rule family="ipv4" source address="12.34.56.78" accept'
Changing the Firewalld Backend
By default, firewalld
uses nftables
. You can switch to iptables
by modifying the configuration file.
Step 1: Open the firewalld
configuration file.
sudo nano /etc/firewalld/firewalld.conf
Step 2: Locate the FirewallBackend
line and change it to iptables
FirewallBackend=iptables
Step 3: Save the file and restart firewalld
You can now use the iptables
command to view rules.
How to Use iptables Commands with Firewalld
For advanced rules not directly supported by firewalld
, you can use the --direct
option to add raw iptables
rules.
Step 1: Add an iptables
rule using the --direct
option. Replace the.first.ip.address
and the.second.ip.address
with your actual IPs.
sudo firewall-cmd --permanent --direct --add-rule ipv4 nat POSTROUTING 0 -p tcp --dport 25 -m statistic --mode nth --every 2 --packet 0 -j SNAT --to-source the.first.ip.address
sudo firewall-cmd --permanent --direct --add-rule ipv4 nat POSTROUTING 1 -p tcp --dport 25 -j SNAT --to-source the.second.ip.address
Firewalld in Failed State
If firewalld
fails, it might revert to a default configuration.
Step 1: Check the firewall configuration.
sudo firewall-offline-cmd --check-config
Step 2: Examine the firewalld
journals.
sudo journalctl -eu firewalld
Direct rules are stored in .xml
files under /etc/firewalld/
. If a rule is causing issues, you can edit or remove it from the corresponding file.
after making changes.
This tutorial should provide you with a basic understanding of firewalld
on RHEL-based systems. Remember to test any firewall changes in a non-production environment first.
