Fix Wi-Fi disconnection issues on Windows 11
Windows 11 users often face the frustrating problem of their Wi-Fi repeatedly disconnecting. This issue can stem from various sources, including system bugs, outdated network drivers, or incorrect power settings. Fortunately, there are several solutions you can try to resolve this problem quickly and easily.
Method 1: Forget and reconnect to your network
This simple yet effective method often resolves connectivity issues by clearing out any corrupted network data.
  1. Press Win + I to open Windows Settings and navigate to ‘Network and Internet’ on the left.
  1. Click on ‘Wi-Fi’ in the Network and Internet page.
  1. Select ‘Manage known networks’ option.
  1. Find your Wi-Fi network and click the ‘Forget’ button next to it.
  1. After forgetting the network, click the Wi-Fi icon in the taskbar and reconnect by entering your password.
Method 2: Update your network adapter drivers
Outdated or faulty network drivers can cause persistent connectivity problems. Updating them might resolve the issue.
  1. Right-click the Start button and select ‘Device Manager’.
  1. Expand the ‘Network adapters’ section.
  1. Right-click on your wireless adapter and choose ‘Update driver’.
  1. Select ‘Search automatically for drivers’.
  1. Windows will search for and install any available updates. Restart your computer if prompted.
Method 3: Change network adapter power settings
Adjusting power management settings can prevent your system from turning off the Wi-Fi adapter to save power.
  1. Open Device Manager, expand ‘Network adapters’, right-click your adapter, and select ‘Properties’.
  1. In the Properties window, go to the ‘Power Management’ tab and uncheck ‘Allow the computer to turn off this device to save power’.
  1. Click ‘OK’ to save changes.
Method 4: Run the Network Adapter Troubleshooter
Windows has built-in troubleshooters that can automatically detect and fix common network issues.
  1. Open Settings and search for ‘troubleshoot’ in the left sidebar.
  1. Click on ‘Troubleshoot Other problems’.
  1. Find ‘Network and Internet’ and click ‘Run’ on the right.
  1. Follow the on-screen instructions to complete the troubleshooting process.
Method 5: Reset network settings
If all else fails, resetting your network settings can often resolve persistent connectivity issues.
  1. Go to ‘Network and Internet’ in Settings.
  2. Scroll down and click on ‘Advanced Network Settings’.
  1. Find ‘Network reset’ and click ‘Reset now’.
  1. After the reset, reconnect to your Wi-Fi network.
Additional tips:
  • Ensure your router firmware is up-to-date.
  • Consider switching between 2.4 GHz and 5 GHz bands on your router.
  • If possible, try using an Ethernet connection to rule out Wi-Fi-specific issues.
  • Keep Windows updated to fix potential OS-related bugs affecting network connectivity.
Remember, if these solutions don’t work, the problem might be with your hardware. Consider replacing your router or network adapter if they’re old or malfunctioning.
