Grouping worksheets in Excel is a fantastic way to boost productivity when dealing with workbooks that have multiple sheets with the same setup but different data. When you group sheets, any changes, formatting, or data input you make on one sheet is mirrored in the same cell locations across all grouped sheets.
Think of it this way: let’s say you’re managing a workbook with monthly sales data and each month has its own worksheet. By grouping these, adding column headers or entering totals in one sheet will do the same for all the others at the same locations.
Benefits of worksheet grouping in Excel
Grouping your worksheets offers some great perks that can really streamline how you work:
- Input or adjust data across multiple worksheets all at the same time.
- Apply formatting changes to all grouped worksheets in one go.
- Configure headers, footers, and page layouts for the whole group.
- Move, copy, or delete a group of worksheets with ease.
- Print multiple worksheets using the same settings quickly.
- Correct errors across multiple sheets, avoiding tedious repetition.
How to group worksheets in Excel
Let’s get into how to actually group those worksheets. Here are a couple of methods.
Method 1: Grouping all worksheets in a workbook
This is the quickest and most efficient method. If you want to affect every sheet, this is the way to go.
- Right-click on any sheet tab and select ‘Select All Sheets’ from the context menu.
This will instantly group all of your worksheets.
- Note: When all worksheets are grouped, clicking on any sheet tab will ungroup them. If you had only some worksheets grouped previously, then you can switch between them without ungrouping.
Method 2: Grouping selected worksheets
If you only want to group specific worksheets, this approach gives you that control.
- To group consecutive worksheets, click on the first sheet tab. Hold down the Shift key and click on the last sheet tab you want to include. This selects and groups all worksheets between the tabs you clicked.
When the worksheets are grouped their tabs turn white from their default light gray, showing they’re part of the group.
- To group non-adjacent sheets, hold down the Ctrl key. Click on each sheet tab you wish to group individually. Release the Ctrl key once done.
Once the worksheets are grouped, any changes you make on one sheet will immediately affect all the others at the same cell positions.
For example, if you enter names in column A and add SUM formulas in column E on the “2015” tab, these changes will appear in the same locations on the other grouped worksheets.
Keep in mind: clicking on any sheet outside a group will ungroup them.
How to know if worksheets are grouped
Knowing if your sheets are grouped is really easy. Look for these clues:
The sheet tabs that are grouped have a white background instead of light gray.
The word “Group” appears after the file name at the top of the Excel window.
How to ungroup worksheets
Let’s look at how to ungroup sheets after you’ve used them.
Method 1: Ungrouping all worksheets
When you’re finished with your group, you can quickly ungroup all the sheets.
- Right-click on any grouped sheet tab and choose ‘Ungroup Sheets’ from the context menu.
This will ungroup all sheets allowing you to work on them individually.
Method 2: Ungrouping select worksheets
You can also ungroup just certain sheets, while keeping others grouped.
- Hold down the Ctrl key and click on the tabs of the worksheets you want to ungroup. Release the Ctrl key once you have selected the desired sheets.
This will ungroup the selected sheets, while preserving the remaining ones in a group.
