Changing the Alarm Sound on Your iPhone
Waking up to the same alarm every day can become monotonous. Fortunately, Apple provides several ways to personalize your iPhone’s alarm sound, from built-in tones to custom songs. Here’s how to change your iPhone alarm sound.
How to Set a Custom Alarm Sound on an iPhone
If the default alarm tones don’t suit you, you can use a song from your music library or purchase a ringtone from the iTunes Store.
Set a Song as Your Alarm Sound
Step 1: Open the Clock app and go to the Alarms tab.
Step 2: Tap the + icon to create a new alarm, or select an existing alarm.
Step 3: Tap on Sound.
Step 4: Choose a downloaded song under the Songs section. Alternatively, tap Pick a Song to select one from your Apple Music library.
Step 5: Go back to the previous page and tap Save in the top-right corner to save changes.
Buy a Tone for Your Alarm
Step 1: From the Alarms tab in the Clock app, add a new alarm or select an existing one.
Step 2: Tap on Sound.
Step 3: Now, tap on Tone Store under the Store section.
Step 4: You’ll be redirected to the App Store to install the iTunes Store app if it’s not already on your iPhone.
Step 5: In iTunes Store, browse or search for a song and purchase it.
Step 6: Once downloaded, go back to the alarm settings and select the purchased song under the Songs section.
Step 7: Go back to the main alarm page and tap Save.
How to Change Your Alarm Sound on an iPhone
If you prefer to use one of the built-in alarm sounds, follow these steps:
Step 1: Open the Clock app on your iPhone and go to the Alarms tab.
Step 2: Tap the + icon in the top-right corner to create a new alarm. Or, select one of the existing alarms to change its sound.
Step 3: Now, tap on Sound.
Step 4: Next, choose a tone listed under Ringtones.
Step 5: Alternatively, scroll down to the bottom, tap on Classical, and select one from the classical alarm sound options.
Step 6: Now, tap Back in the upper-left corner to go to the main alarm screen and tap Save in the top-right to save the alarm settings.
How to Change Alarm Sound Vibration Pattern on iPhone
You can customize the vibration pattern for your alarm, or even disable vibration altogether.
Step 1: In the Clock app, go to Alarms, and either add a new Alarm or select an existing one.
Step 2: Tap on Sound and choose Haptics on the following screen.
Step 3: Next, choose one of the available options under the Standard section.
Step 4: You can choose the None option if you want to disable vibration for the alarm clock on your iPhone.
Step 5: Alternatively, tap on Create New Vibration.
Step 6: Tap with your fingers on the screen to record a new vibration pattern.
Step 7: Once done, tap Stop, then Save in the top-right corner.
Step 8: Give your vibration a name and tap the Save button.
Step 9: Finally, go back and tap Save to save the alarm.
Personalizing your iPhone’s alarm sound and vibration can significantly improve your wake-up experience, making mornings a little less jarring. With a range of customizable options, you can tailor your alarm to perfectly suit your preferences.
