Google Docs, a popular online word processor since 2006, offers multiple ways to create documents, including brochures. You can either use pre-made templates or design your own layout with available tools. Templates offer a quick solution, while designing from scratch allows for complete customization.
There are primarily two approaches to making brochures in Google Docs: using a built-in two-page template or creating a three-fold brochure using tables. Let’s explore these methods in detail.
Method 1: Two-Page Brochure Using a Template
The fastest way to create a brochure is to use one of Google Docs’ built-in templates. This approach simplifies the process, delivering a professional look without the hassle of designing everything yourself.
To start, go to docs.google.com. Click the Template Gallery button in the top-left corner to explore the available templates.
Scroll to the Work section. Here, you’ll find brochure templates, like Modern Writer and Geometric. For this guide, we’ll be using the Geometric brochure template.
This template provides a ready-made layout that you can customize. Start by replacing the example text with your company information and address at the top. Then, change the brochure title and date to match your needs.
Use the toolbar to change headings and body text, adjusting font styles, sizes, and colors. The first section usually features an overview of your product or service, which should be engaging and brief to hold the reader’s attention.
To add your own visuals, replace existing images by right-clicking, selecting Replace image, and choosing a new image from your computer or another location.
The second page is for detailed information. Replace the placeholder text with relevant, value-adding content. Remember to make the information clear and add images or graphics to enhance its appeal.
Using templates is an efficient way to ensure a professional result while saving you time on layout.
Method 2: Designing a Three-Fold Brochure from Scratch
If you need more customization, creating a three-fold brochure from scratch allows for more flexibility in design. This type of brochure has three sections when folded and is often printed on both sides, providing more content in a compact size.
Change the page orientation to landscape. Click File in the top-left corner.
Choose Page setup from the dropdown menu.
In the Page setup dialog, select Landscape orientation and set all margins to
0.25
inches. Click OK.
Insert a table to create the brochure’s columns. Place your cursor at the top of the page, click on the Insert menu, choose Table, and create a
3x1
table.
The table will be one row with three columns.
- Expand the table to fill both pages. Click inside a table cell and repeatedly press Enter until the table extends to the bottom of the second page.
This structure mirrors the folds of a three-fold brochure. Visualize this by folding a paper into thirds to understand where content should appear.
- Add content to each section. Insert text, images, and other elements for each panel. The first page is the brochure’s outside, and the second is the inside.
Inserting Images into Your Brochure
Adding relevant images enhances your brochure.
Place your cursor where the image should go. Click Insert, hover over Image, and select your image source, like Upload from computer.
Choose your image and click Open. It will be placed in your document. Resize and move it as required.
Use images that match your text to keep readers interested and convey information visually.
Finalizing Your Brochure
Once you’ve added all your content, remove the table borders to get a clean, finished look.
Click inside the table. Right-click and choose Table properties from the context menu.
In the Table properties sidebar, find the Table border section. Set the Table border width to
0 pt
This action removes visible borders when printing or sharing the brochure.
Creating brochures in Google Docs, through templates or manual design, lets you create professional-quality materials. By following these steps and adapting content to your requirements, you can communicate effectively.
